Old 06-27-2013, 06:02 AM   #1
Originally Posted by annn View Post
Your a god ! The st relay was causing the starter issue & maybe more. Should I replace relay ? Pal says once their bad it can happen again ? Also do you think that the st being stuck could have caused so much electrical chaos ? Car seems to be fine now , I think the crank sensor caused the initial issues with shifting and some how in all this the st relay got stuck & really caused problems . Thanks for all the help ,it was truly a correct direction !!
Definitely replace it, as once the contacts stick they will do so again. It is possible that it was the root of all evil.
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 12:01 AM
