My ECHO was a manual and the transmission shifted very smoothly. In fact when my legs and feet made shifting difficult I did a lot of shifting without the clutch whenever possible.
I sold the ECHO and bought a Yaris in order to get an automatic transmission because I figured if I kept shifting w/o the clutch I would ruin the transmission. But I often wonder if I had kept the ECHO would the trans have held up? I think the ECHO, for my purposes, was a better car other than the trans.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
I liked my Echo better. The Yaris isn't bad, but the Echo was better (both manual transmission cars).
#3 | |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
2007 LB W/Cold Wx Package |
![]() ![]() Drives: Mazda Protege5 Join Date: Jan 2007
The key thing is shifting at the correct RPM. If you do, then no harm done. You'll know, as it's smooth when done right.
#5 | |
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
As far as reliability goes, I'm at 85k miles and have only done oil changes and oil filter changes on the car since getting it. I've changed the cabin filter a few times and vacuumed the air filter. Don't mean to thread jack but are there other maintenance items other people reccommend? |
#6 | |
Clean the leaves and crap out of the windshield wipers shafts where they go into the body and that area or they will rot and rust the car over a long period of time. Also open the trunk and clean the rotting stuff around the rubber sealing strip. Open the hood once a month when you check the oil and look for pink coolaand splashes on the right bottom that indicated a leaking water pump. I take the car to the car wash four times are year for interior and experior cleaning and consider that maintenance now that Im too old to do it myself. You dont want a car like my wifes Camry with is filthy and has a trunk full of crap!
![]() Drives: Yaris Hatch,Celi 3SGTE,GC8 Join Date: Apr 2006
When I swapped my cluster to a Canadian with tach it had 177,556 miles, the new one had 56,000 kms on it and today I swapped it for a 2010 S cluster it had 192,000 kms, so 192,000kms - 56,000kms =136,000 kms = 84506 miles + 177,556 miles = 262062 miles on my PR Spec 2006 Hatchback. Nobody believes me but my car has the same brake pads from new, the only things that I have changed are:
1. Motor Oil & Filter (obviously) 2. Tranny Oil (manual) 3. Serpentine Belt 4. Air filter 5. Cabin Filter 6. Tires 7. Rear driver wheel bearing 8. Spark Plugs (2 times) Also maintenance is by the book so just Imagine how many times I've changed the oil and tires I would like to know if the ECU keeps the mileage data so I can have proof
#8 | |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Unbelievable!!
This car has so far done 12 hour trip and back, 5hour trip and back and today i took it to Dubbo 5 hours to and back with no dramas. I was thinking if this car breaks down here in the middle of no where with no signs of civilization or gas station. It just kept chugging a long. Impressive 7 years old and tough as nails. ![]() Nothing is wrong with it except MY Brother reversed into it |
The 'rotating wheel' on the Yahoo! homepage lists 'Top Cars Under 25K' as one of the panes to choose. Under that headline, the next line reads: Priced at just $16,020, one Japanese compact is the second highest rated by Consumer Reports. Top 10 picks (the 'Top 10 picks' is highlighted)
I wanted to see the results...so I clicked on the 'Top 10 picks' link. The first line on the linked article is: '10 most reliable cars under $25,000' I KNOW the Yaris is one of the 10 most reliable cars under $25,000', so I scrolled down to see the cars. No Yaris! So...I read the article. IMO, the key line is: 'To create a list of truly good cars, we also made sure the final roster only included those models that meet the criteria for a Consumer Reports recommendation, including performing well in our road tests and in safety tests conducted by the government and/or insurance institute'........ ![]() ![]() :r olleyes: .....hubris much?The title of the article should have been amended by adding 'from Consumer Reports pre-approved list'..... ![]() ![]() ![]() .The $16,020 Japanese compact at #2 is the Fit. The only car that beat the Fit is the Scion xB.......see URL below. (For some reason it doesn't show up as a link. I tried to put it in the body of the post and this made the rest of the post disappear) autos.yahoo.com/news/10-most-reliable-cars-under-25-000-193000372.html |
25, 550 MILES!
Yahoo! & Consumer Reports
I copied & pasted the link, works fine -
Wow, Yahoo! Consider the source (s) Yahoo is complete trash & I wouldn't take Consumer Reports advise rating toothpicks, even if my life depended on it !!! ![]() Real world experiences are the best way to determine if a particular product is right for you. 'The title of the article should have been amended by adding 'from Consumer Reports pre-approved list'..... ![]() ![]() ![]() Indeed What a crock of
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
