![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Yep :-)
I just ordered the clockspring before even checking the codes, because the symptoms were such a perfect match to what CTScott described in the various threads. Reading codes was tricky; I believe the best method (which I didn't do) is to remove the little box above the ODB port, and insert paper clips from above. I connected crocodile clamps with wires to the paper clips so I could short it while also sitting in a position to see the codes flash on the dashboard. And note that even if 51 is the code for clockspring (and some other possibilities), I had two unrelated codes that also went away after replacing the clockspring. |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 12:35 PM |
| Fan Not Spinning Up, Random Airbag Light | drannonb | DIY / Maintenance / Service | 12 | 10-23-2012 03:33 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
