Old 07-09-2013, 04:30 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Originally Posted by nookandcrannycar View Post
Welcome. The only 2 suggestions that occur to me off the top of my head are:
1. Pay attention re keeping your tires inflated. Increasing PSI has more of an effect (positive) on MPG than any other car I've owned (and of course the converse is true as well). Many of us inflate our tires above the PSI rating on the tire...some of us by 3-5 PSI and a few fanatical people over 20 PSI.
2. One member posted a test that you can put your clutch through to judge its 'health'. I have found this to be quite valuable. If you search 'clutch test' that post will probably come up as a hit.
Thanks for the tips. I dont plan on checking for clutch life since the car only has 27k miles on it and a family friend helped us buy it. Now a couple of my friends have told me I did a bad decision by getting a newer car but again my parents wanted a car with less chance of breaking up.We've had bad luck with those.
Do you have any dos and dont on manual? I've checked a couple of threats arguing against using the parking break to not roll on a hill and putting it in gear when parking to prevent it from rolling. I wonder if those will damage anything?
A little from me so you guys can know my prior experience.
I learned for about 1 hour on a mazda 2 and an old jeep and relative to those I feel the gas takes a bit to make the revs go up and the clutch catch point still takes me a bit to get it precisely.
Pardon the horrible grammar
vaironl is offline   Reply With Quote
Old 07-13-2013, 11:40 AM   #2
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Hillside clutching.
With your right foot on the brake, release the clutch slowly until you feel a slight engagement (don't stall). Then quickly slide your right foot to the gas pedal, push the gas immediately, as you release the clutch.
Until you master it, if it keeps you from stalling, parking brake use, is perfectly fine.
Too much arrogance around here!!
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
New Yaris owner! kiana808 New YARIS Purchase Forum 11 05-01-2011 10:13 AM
