Old 07-15-2013, 09:28 PM   #1
sickpuppy1
Drives: 2010 Yaris Sedan
I will do that. Wondering if the OEM built in relay can be weak? doesnt this set up (refering back to your stebel install a few years ago) go thru the oem relay too?
Old 07-16-2013, 06:20 AM   #2
If you are using my DIY from my Stebel install, the OEM relay is still used, but only to drive the coil of the second relay, which draws very little current. The Stebel horn is a tad over what the OEM wires (as opposed to horn relay) are rated for.
If your relay is clicking, but you don't see the power through it being switched through the contacts, then it may be a case where the relay contacts are not being pulled in all of the way, due to the voltage to the coil being too low. That can occur if you have a bad ground connection.
My car's electrical system just stopped working today..? jamhot18 DIY / Maintenance / Service 14 11-04-2018 01:40 AM
Power Windows Stopped Working MyzticZ3r0 DIY / Maintenance / Service 4 04-04-2013 03:50 PM
Issue on rostra cruise control. Stopped working!! marcus DIY / Maintenance / Service 1 03-25-2012 04:42 PM
Electric Windows Stopped Working !?!? MattyP DIY / Maintenance / Service 0 09-14-2010 07:20 AM
Help! Horn just stopped working. steveh74 General Yaris / Vitz Discussion 14 09-17-2009 10:23 AM
