Old 07-18-2013, 02:59 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Congrats and welcome to the forums!
Not all Yaris models have that lever that you mentioned, but I believe you need to pump it to elevate and pull on it to go down.
The pedals are indeed a bit high but you will definitely get used to them. I'm not sure if you got a manual, but if so make sure you step on that pedal all the way to the bottom to make sure the clutch is engaged before you switch gears. It's a common issue with pedals this high.
The room in this car is one of the things that sold me. It really is a super versatile car. You did good, gollygirl!
Old 07-18-2013, 03:22 PM   #2
nookandcrannycar
Welcome!
I was going to ask if your car was assembled in Japan or = one of the recent arrivals from France, then I noticed you live in Australia, not in the U.S.
Just out of curiosity, do you know the assembly point for your Yaris?
Old 07-18-2013, 05:30 PM   #3
gollygirl1
gollygirl1's Avatar
Drives: YR Yaris 2013
Originally Posted by nookandcrannycar View Post
Welcome!
Where will I find out where she is built? I saw the build (production) date as June 2013 but not the country. Where should I look for that?
gollygirl1 is offline   Reply With Quote
Old 07-19-2013, 04:20 AM   #4
nookandcrannycar
In the U.S. it is listed on the FACTORY Window Sticker that summarizes the base cost, the cost of any options, and the destination charge.
Old 07-18-2013, 05:32 PM   #5
gollygirl1
gollygirl1's Avatar
OK I shall try to pump it tomorrow when I am home - just dont want to have a problem when I have to get to work. The manual does not really explain that part well.
The car is an automatic - just find that brake pedal a little bit high to my old car but as you say, I am sure in time I will get used to it, it really is my only complaint............and it is something you dont notice so much with a test drive, only when on your own.
new yaris owner from france^^ zenabi New YARIS Purchase Forum 2 05-15-2011 04:40 PM
New Yaris Owner sutorii General Yaris / Vitz Discussion 1 12-17-2010 05:30 AM
First time AutoX with the Yaris Keith Tinari Tracking, Racing, Auto-X Forum 52 11-20-2009 02:38 AM
