Old 07-20-2013, 12:27 PM   #1
Davaross
Drives: 2002 3Dr Gs
Just been for a drive and the light only flashes below 5mph. Unit works fine. Can anything on the obd port cause damage to the ecu or engine?
Davaross is offline   Reply With Quote
Old 07-20-2013, 03:13 PM   #2
The first gen yaris is ISO9141 compliant, as opposed to CAN Bus, like the 2nd gen. The SIL pin (pin 7) is used for OBDII Comm as well as for some special Toyota specific functions.
It may be that ScanGauge has not tested their device on a MK1 European Yaris and that the devices is sending out a command that accidentally triggers a Toyota specific diagnostic mode.
Old 07-20-2013, 09:44 PM   #3
Davaross
Drives: 2002 3Dr Gs
Thanks for the replies everyone, I have just tested it with a friends OBD II Bluetooth adapter which has an activity indicator on it. This flashes in time with the P/S light on the dashboard below 5mph, is it possible that the P/S light is acting as an OBD interface indicator. Also CTS the OBD reader did not find any diagnostic codes on the ecu but if the scangauage is conflicting with one of the Toyota indicators will this cause me an issue next time I take it to the dealership?
Thanks,
Chris
Old 07-20-2013, 10:12 PM   #4
Thanks,
Chris
The PS light should not be acting as an OBD activity indicator, so I suspect that the ScanGauge and bluetooth devices are both CAN and ISO 9141 capable and that the initialization sequence is triggering something to make the ECM flash the indicator.
As long as the check engine light does not come on, there should not be an issue with your next dealer visit.
Fog Light Install Question - Should Be a Piece of Cake for YarisWorld Veterans Tomatogrower DIY / Maintenance / Service 24 10-03-2014 04:38 PM
ScanGauge II Clean Install Ratz DIY / Maintenance / Service 11 03-03-2012 09:10 PM
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Sirus Radio install question brpnagger Cosmetic Modifications (Exterior/Interior) 5 06-25-2007 09:21 AM
