Old 07-23-2013, 02:51 PM   #3
Toyota3000
Drives: Yaris 2001 CDX
It is indeed a loose or worn belt. Once you run it loose for a bit it gets "glazed" on the contact surface and at that point no matter how much you tighten it it will squeal at least at startup.
The Yaris belt is under $20 US and it quite easy to replace, so your best bet is to do so.
Thanks Scott. And what if I preferred to tighten it rather than get a new one ? - is there a vid or diagram to show this ?
Toyota3000 is offline   Reply With Quote
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 10:22 AM
Belt noise after MI pulley? Captain Slow Performance Modifications 33 07-31-2013 02:11 PM
squealing belt dferguson2 DIY / Maintenance / Service 9 06-19-2012 11:13 PM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
