Old 07-24-2013, 03:40 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
It is not uncommon for the inside of the outlet to rust. Check the 15A CIG fuse in the fuse panel that is under the bottom of the dash to see if it is popped.
So all i have to check is if the fuse wires are broken (not touching), correct?
vaironl is offline   Reply With Quote
Old 07-24-2013, 04:09 PM   #2
Correct - The metal piece inside of the plastic should be complete.
Old 07-24-2013, 04:30 PM   #3
vaironl
vaironl's Avatar
It doesn't seem broken but it looks like if its burned, literary like if someone held the metal parts over fire.
Old 08-04-2013, 09:12 PM   #4
vaironl
vaironl's Avatar
Hey Scott, I'm sorry to revive this thread now. I don't know why I didn't posted my problem, but after placing the new fuse the power outlet still didn't work. I'm guessing I will have to remove the panels and do some work. Do you think I can follow this DIY: http://www.yarisworld.com/forums/showthread.php?t=9431 ?
Might I need additional tools?
My car has the same panel and the outlet is in the same spot. I will replace the outlet itself because it looks like this
2007 yaris sedon power outlet problem 23carlie23 DIY / Maintenance / Service 2 03-21-2010 10:36 AM
