Old 07-29-2013, 04:32 PM   #1
33OH
Drives: '08 Yaris
I don't see how installing a wheel could bend a drum, but your whole story sounds pretty crazy to begin with.
I can't believe diagnosis was $90 to determine you had bent wheels, it takes literally seconds to throw them on a balancer.
Also, you said the bent wheels were on the front, and drum brakes on our cars are on the back.
I'd take the car to another mechanic/shop, tell them you were told you need a drum brake change, and hope it fixes everything.
An easy way to tell if it is bent would be to take a wheel off the back, and visually eye it up or take a straight edge. Or place the car on jackstands and rotate the rear drums to see if they wobble.
Bent wheels = scrap.
Old 07-29-2013, 05:38 PM   #2
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Sounds like somebody used a 3/4" impact set on kill to tighten the lug nuts.
Old 07-29-2013, 06:46 PM   #3
angrygenerator
Drives: 08 Yaris
I am just back from the shop. It turns out that my car's drums are okay. Apparently when my wife had to brake to avoid something on the road, one of the rotors got damaged. The guy also told me that the weights on the rear wheel apparently had come loose and were causing to shake.
angrygenerator is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
