Old 07-31-2013, 06:48 AM   #1
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
Hello everyone. I bought the pieces of picture 1, I installed according to picture 2 3.4, but the result was negative, to me does not work. I 1ND-TV engine, 1.4 D4D 66kW respectively. Can someone help me? You need to do something else than I did? Have to change terminals 1 and 2 of the 4-pin connector in the 10 pin?
geoded is offline   Reply With Quote
Old 07-31-2013, 07:50 AM   #2
You have everything installed in the proper place, but according to the wiring diagrams the 1ND-TV Yaris does not support cruise control.
Check the connector on the other end of the spiral cable, which is located under the cover for the lower part of the steering column. The question is if the two wires are present there that would connect to the cruise control stalk wires under the airbag.
Tags
cruise control. 2012
