Old 07-31-2013, 11:20 AM   #1
3cyltrbo
Check this thread. http://www.yarisworld.com/forums/sho...header+problem
His issue was not putting the gasket on. Looks like yours is on, but did you check?
Yup, I'm sure the Gasket (round donut) is on
Originally Posted by xnamerxx View Post
Make sure you're not using the bolts from the muffler.
I haven't been anywhere near the muffler yet
Originally Posted by tooter View Post
Yeah, send it back and get a Weapon R.
They have no fitment issues.
I would love to but (I'm impatient and I have a show this weekend)
Originally Posted by 7:34pm View Post
what about if you remove the o2 sensor and flip that one bolt so the head is against it?
I can't do that with the factory bolt because of the way its flanged
That looks like the older, defective DC Sports design, where the O2 sensor bung was incorrectly placed. They have corrected that issue.
Wish I had known this before I bought it
Originally Posted by 47_MasoN_47 View Post
I had that problem, but for me it was due to forgetting to put that little gasket between the header and the midpipe.
As above, I am 100% certain that the donut is installed.
Originally Posted by mario98c View Post
Cut the tip of the bolt and problem fixed! lol
I guess the pictures don't do it justice, the O2 sensor is almost rubbing on the flange as is / I'd have to cut almost all the thread off the bolt
3cyltrbo is offline   Reply With Quote
Old 07-31-2013, 12:26 PM   #2
Another option would be to weld a new bung in a better location for the O2 sensor and plug the existing hole.
Old 07-31-2013, 12:46 PM   #3
3cyltrbo
Originally Posted by BEEF View Post
I'd go without the header for the show (put the factory one back on) and send it back. The longer you keep it, the harder warranty stuff will be.
I am actually a big fan of the Weapon-R (I has one) and would recommend it. There is also a huge price premium between the two... and I haven't heard of any issues with them.
I've thought of putting the factory one back one, but I've been chomping at the bit to have a header
I paid $250 ish and I find the Weapon R for about $230 ish / not sure why I went DC sports in the first place?
I am totally considering that!, only problem is it would most likely read off just one cylinder (although I think I've read about others that had a similar setup and didn't experience any drawbacks)
A day out with mechanic went wrong- Right arm problem talhahs DIY / Maintenance / Service 6 05-17-2013 05:20 PM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
