Old 08-05-2013, 12:21 AM   #1
bryanhoule
Drives: 2007 Toyota Yaris MT LB 2-door
My experience
Regarding the low idle, I experienced it as well, and it was also temporary. I just replaced my original spark plugs (they were Denso) with new NGR IFR5T11, at 82,000 miles. Original plugs looked pretty good as far as I could tell (not an expert). They all looked the same, which I'm sure is a good thing (don't need to be an expert to know that).
Anyways, after driving around the block a few times for the first time since installing the new plugs, i parked at home and let it idle. RPM was around 450 to 500 RPM, and causing a semi shaking/ vibration of the car, that i could physically feel. i rev'd the engine for a minute or so and it went away and hasn't come back.
My theory is that the CPU is somehow re-calibrating to the new plugs, but that's only a guess.
By the way, replacing your own spark plugs is easy! I didn't use a torque wrench (too expensive), but was cautious to not overtighten, just snug. i used a "single hand" method to be sure i wasn't overtightening. Also, I put a very small amount of anti-seize on the threads.
bryanhoule is offline   Reply With Quote
FS: Denso Iridium POWER plugs NIB "G" Items for Sale by private party 60 03-22-2013 08:11 PM
So You Just Have To Have Iridium Spark Plugs eh? bronsin General Yaris / Vitz Discussion 32 04-17-2012 02:14 PM
Spark Plugs platinum vs iridium Hard_Yaris Fuel Economy Forum 21 04-11-2010 09:37 PM
Where can I get iridium spark plugs??? fidgell Canada 4 03-01-2010 12:10 AM
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 08:34 PM
