Old 08-05-2013, 07:04 PM   #1
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
The CV joint would sound more like it..
Can it be the shock ?? I dont know how the top plates work on this car, but when i pop the hood, i can see the shock, but there are now screws holding it. All i see is a black rubber about 3 inches in diameter.. How do you remove the shock on this thing... anyways im scheduled wednesday morning for another road test..
yaris1F8 is offline   Reply With Quote
Old 08-05-2013, 09:17 PM   #2
The top rubber thing is just a cover. under there is the threaded top of the strut, which has an allen recess in the top of it (to hold it while removing the top nut). A broken spring would be more likely to make noise than a bad shock.
Old 08-05-2013, 09:39 PM   #3
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Thanks CTScott , ill let you know when im done on wednesday.. i know im hearing a pop coming from the drivers side, it does not do all the time.. just so freakin annoying.. grr
not so good of an experience Schutzhund3 General Yaris / Vitz Discussion 42 12-22-2011 09:46 AM
