Old 08-06-2013, 11:53 AM   #1
3cyltrbo
The battery was disconnected through the entire upgrade process (the battery was actually one of the things that I upgraded)
And it has been disconnected since the install of the engine stuff as well (I've been working on the headlights and audio after doing the intake and TB, so I've had other occasion to disconnect the battery)
Its also worth mentioning that I don't have any seemingly bad side-effects other than a super high idle when the car is cold (first thing in the morning). Other than the high idle, everything seems "okay" (other than the fact that I think I've lost 10hp)
Will
3cyltrbo is offline   Reply With Quote
Old 08-06-2013, 01:45 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Will
Hey Will,
I have a 100% satisfaction guarantee. If you don't like the tooter, send it back to me and I'll refund your money, You'll only be out the return shipping cost. Then you can buy Garm's manifold if you think it will solve your problems.
Personally I think that something else is wrong, but that's not for me to figure out. So just send it back for an immediate full refund.
Greg
Old 08-06-2013, 03:06 PM   #3
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
Hey Will,
Greg
^^Awesome Customer Service!
But I wouldn't jump ship just yet, try some of the solutions offered. I'm no tuner but something is telling you that your not running optimal A/F ratio. Just swapping out the intake, I highly doubt, will solve your issues. I'd at least try the below solution:
Did you disconnect the battery after installing the throttle body to reset the fuel trims?
Did you per chance install each thing separately, where you could see the difference with each part?
If not, I would suggest reversing the process one by one, starting with reverting to the stock throttle body.
or
Originally Posted by Jason@SportsCar View Post
I would ditch that thermostat, that is way to cold, no reason at all for that on a street car - much less in the great white north. The ECU is probably dumping fuel in there in an effort to get the temp to what it thinks is normal, rich does not make power.
thats where your loss is from... go with the MI/GE one
LOL... you must be some expert to come to that conclusion... so quickly. Sponsored much?
JustDidIt is offline   Reply With Quote
Old 08-06-2013, 03:16 PM   #4
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
LOL... you must be some expert to come to that conclusion... so quickly. Sponsored much?[/QUOTE]
nah just a huge supporter.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
