Old 08-06-2013, 01:41 PM   #1
I think that was meant playfully, not as a real suggestion. At least I meant it that way. Sorry to confuse the issue.
if I remember they were marginal losses, and that was without a 1zz TB. Nothing like what I'm feeling / and not all where I'm feeling it either (I'm also feeling a lack of top end (not that it was a screamer before) )
Hey, you asked. I gave my opinion. Even a marginal loss is not a gain. Possible vacuum leak somewhere, maybe? Have you checked all the connections and listened for leaks?
You might try going back to a stock TB and see if that cleans it up at all. Our manifold accepts either throttle body, I'm not sure about the Tooter.
Remember, you've changed two or more things at once. It's best to change one thing at a time to see what the result is.
Old 08-06-2013, 01:49 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I am. It works with both throttle bodies.
Old 08-06-2013, 03:14 PM   #3
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
lol yeah I was merely jesting. I mean, yeah you'd get power haha, but I know most people don't want to dump 33% of the cost of the car into a supercharger.
Old 08-06-2013, 04:19 PM   #4
3cyltrbo
I have listened (my family calls me Miracle ears), and to the best of what I hear there weren't any leaks.
Of the areas where there could be a leak (below) they all seemed fine.
-Intake manifold to Head = check
-Throttle body to Intake manifold = check
-Intake piping = check
-Brake booster vacuum line = check (factory line)
-Evap system vacuum line = check (factory line)
-CrankCase vacuum line = check (exact specs as factory, only 1 inch longer)
-CrankCase fresh air line = check (breather)
-Exhaust Manifold to Head = Check
-Exhaust Manifold to downpipe = Check
-O2 sensor = check
I might start with just swapping back the OEM TB (Like many have suggested) and go from there................
3cyltrbo is offline   Reply With Quote
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
