Old 08-07-2013, 03:40 PM   #1
Originally Posted by 3cyltrbo View Post
Green coolant light???
um????
I think I have a blue???? light when the engine is cold, but it goes out almost instantly in the summer, and only stays on briefly in the fall and spring.
I actually know the exact water temps because I've been driving around staring at my Scan Guage. ............................???
OK. On the Canadian clusters it must be different. On the US ones we have a little green indicator. Mine takes about 1/2 mile from my house to go out.
What are you seeing for temps? Normally the Yaris will sit in the low to mid 180's F when cruising.
Old 08-07-2013, 03:45 PM   #2
3cyltrbo
I'll take my toy (The Yaris) for a drive tonight and pay attention to both the color of the light (when the car starts) and the water temp (in deg F)
Will
3cyltrbo is offline   Reply With Quote
Old 08-07-2013, 03:51 PM   #3
Will
For my car on the freeway, my coolant runs between 179-184*. City driving goes from 180-190's. Parking lot goes up to 202, or around there where the fan kicks in. lol
Old 08-14-2013, 12:38 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
x2
Old 08-12-2013, 11:34 AM   #5
3cyltrbo
You were RIGHT (sorry my bad) the light IS GREEN, but at this time of year it is almost never ever on when I first start the car (even after its been sitting for days which is usually the case)
I drove it briefly yesterday and I was seeing temps in the 140 - 175 range when cruising (outside temperature was approx 91)
Old 08-12-2013, 02:15 PM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Those temps are in engine warm up territory so the ECU will still be supplying a rich fuel mix. I'm not certain, but there's a chance that the timing parameters during the warm up cycle might also be different.
Be sure to let me know what happens, because if you're not satisfied, you get your money back.
Greg
Old 08-12-2013, 02:53 PM   #7
Greg
167F to 212F is considered normal (post warm-up) operating temperature to the ECM. Below that is the "cold start mode"
Once the engine gets past the cold start range, the coolant temperature is still used for camshaft timing control:
"Camshaft timing control is performed according to engine operating conditions such as the intake air volume, throttle valve position and engine coolant temperature."
So, I still think that Jason's take on the performance thermostat being the culprit has merit.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
