Old 08-07-2013, 05:46 PM   #1
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
No. The Prius headlight switch has different connectors.
Does the Prius headlight switch physically fit in the Yaris though? Could we possibly get a Prius headlight stalk connector and swap the Yaris pins into it for it to work?
Just wondering if any of this is possible since a Prius headlight switch with fog control can be found for half or less than half the cost of the Yaris stalk with fog control.
D&D is offline   Reply With Quote
Old 08-07-2013, 06:31 PM   #2
I believe the stalk would fit, but the function is very different as the Prius headlight stalk is an input device for the body ECU, which then does the light control switching. It most likely could be made to work, but may require adding a couple of relays.
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
