![]() ![]() Drives: Yaris 1F8 Join Date: May 2013
Ok but what if i put it tighter... iv given it couple of turns...
Tell me CTScott does the front end need to be off the ground to tighten up the top shocks.. do i have to use the hex also to tourq it ? |
#2 | |
You don't have to have it off the ground to tighten them. If the shaft looks to be rotating then you have to use the allen wrench. If you are using a socket, it is very difficult to tell if it is rotating.
I purchased a set of box end keys... at sears, craftsman life time warranty .. so with this i can see if the hex is turning.. The shock is nice and tight now.. Since i have a small slope in my garage ill check it tomorrow when i pull her out..
Why were the back shocks so lose..? I was moving them with my hand.. but now they are nice and tight.. |
Ok after tightening up all the shocks, car is going a lot smoother.. now ill have to tighten up the ball joints and tye rod end..
| Stock HU Remote Toggle Switch Wiring Question | marco_george | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-13-2010 09:20 PM |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Feeler question? | Cutie Pie #2 | Items for Sale by private party | 4 | 08-18-2009 04:03 PM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
