#19 | |
play every day
the MET fuse the IGN fuse the IG2 fuse Here is the engine compartment fuse box layout: ![]() There is power to the ECU #1 fuse under the dash. ![]() The under dash registry. ![]() I used an AM radio to pick up powered and unpowered fuses as it "ticks" when they are removed and reinstalled. on the ones that didn't tick, I confirmed no power with a multimeter. Last edited by tooter; 08-09-2013 at 07:48 PM. |
#20 |
play every day
I tried a test. Removed the MET fuse, stuck a spade terminal in the socket and jumped it to the positive battery terminal. The dash gauges turned on. Put everything back together and it's still the same no go...
#21 | |
Power flows to the MET fuse as follows: 1. 80A MAIN fuse on positive battery terminal 2. 50A R/I Fuse 3. Contact of IG2 Relay IG2 relay coil power flows as follows: 1. 80A MAIN fuse on positive battery terminal 2. AM2 Fuse 3. Power enters ignition switch connector on white wire (AM2) 4. Pink wire on Ignition switch connector (IG2) feeds the coil I missed the R/I fuse when I was looking before. Check him next, and if it is not him follow the two flows above.
#22 |
play every day
Ok. I'll check the chains of command. Ok. Found the 50 amp R?I. A red single.It takes a real wiring catastrophe to blow a big fuse, so I sure hope it isn't blown.
edit: It's good. I'll go through the others tomorrow. Last edited by tooter; 08-09-2013 at 11:11 PM. |
#23 |
It should be one of the big boys in the under-hood fuse panel. Actually it is the square red one between the 7.5A and 20A fuses on the right side of your picture above.
#24 |
play every day
Yes. Checked the 50 amp last evening and it's good. I'll check the rest today.
#25 |
play every day
Bingo, Will.
![]() AM2 fuse. Everything works fine now. the most likely reason is that I was defeating the clutch pedal start disable switch and I'm pretty sure that the ignition switch was in the ON position while I was doing it. Thanks so much for taking your time to offer such a precise troubleshooting sequence. ![]() Regards, Greg |
| When cold starting, almost sounds like opening a fresh 2-liter Coke bottle | Shinare | DIY / Maintenance / Service | 8 | 06-03-2013 04:18 PM |
| 2009 Yaris starting issue -need help | cudchew | DIY / Maintenance / Service | 15 | 12-16-2011 02:24 AM |
| Yaris Starting Mystery – Help Please! | ceilingwalker | DIY / Maintenance / Service | 3 | 11-10-2011 05:35 PM |
| Problems starting the engine | fmicle | General Yaris / Vitz Discussion | 10 | 10-07-2009 08:48 AM |
| Starting Engine - Yaris Hatchback M/T | gbuks | General Yaris / Vitz Discussion | 2 | 11-06-2008 12:24 PM |
