Old 08-12-2013, 12:39 PM   #1
Nadial
Drives: 2009 Hatchback
Parking light is not an input, it is an output, so your device will output +12V to pin 29 to flash the lights.
Hi guys,
First off, great forum, I have searched for a couple of days and found all the wires (even how to wire throught the firewall ) for my DIY alarm install on my 09 two door hatchback, or so I thought.
Surely this is a noob question, but I cannot get the parking lights to flash. My sp-101 manual depicts two (white) 12v flashing light outputs (7.5 amp x 2).
I have tried:
Connecting one white wire to pin 13, parking light (-), on the 13-pin plug by the headlight switch without success
Connecting one white wire to pin 29 (green wire), parking light (+), on 30-pin plug 4A in the dash fuse box without success.
I have tried alternating the two white wires in both positions as well.
It might bear mentioning the the the 12v power input is connected to the gray wire, pin 5, on the 8 pin plug by the ignition swith. Which is supposed to be constant 12v.
Thanks in advance
Nadial is offline   Reply With Quote
Old 08-12-2013, 01:20 PM   #2
Originally Posted by Nadial View Post
Hi guys,
I have tried:
Thanks in advance
If you have a green wire in your headlight switch connector, in place of one of the white/black wires, then you would have to use the Pin 29 + connection, instead of the pin 13 white connection.
Check the 10A TAIL and 7.5A PANEL2 fuses in the fuse panel that is under to bottom of the dash to see if you popped one of those fuses. If you connected to - output to pin 29 you would pop it.
Old 08-12-2013, 02:05 PM   #3
Nadial
The 10A tail is fine, there is no panel 2, only a 7.5A panel 1 beside the 10A tail, and it is fine.
This is what I have for the headlight switch connector
Sorry I had to use a picture from another forum, best I could do in short notice.
I tested the connection for continuity.
The one thing I noticed is that the left front parking light (inside the headlight assembly) is burned out.
Thanks
Old 08-12-2013, 02:56 PM   #4
Thanks
OK. In that case, if you simply jump the white wire to one of the white/black wires (you can use a paper clip or piece of wire to do so, you should see the tail lights come on). This would do the same thing as the parking light - output on the remote starter.
If you do, then something is not configured correctly with the remote starter or the connection to that wire is not good.
Old 08-12-2013, 03:55 PM   #5
Nadial
Jumped the wires and the tail lights came on. Made sure the connection between the alarm and the white wire on the plug is fine. Reset defaults on the alarm as well, no luck.
I am out of ideas. Maybe just live without the lights flashing.
Old 08-12-2013, 04:17 PM   #6
It sounds like that output is bad on the remote starter.
Old 08-12-2013, 05:44 PM   #7
Nadial
Unfortunately I think you are correct. I've already got the alarm wired, maybe the guy I bought it from will give me just a new module, because I don't want to undo everything I have done.
Thanks again for your efforts CTScott
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
