Old 08-12-2013, 02:05 PM   #1
Nadial
Drives: 2009 Hatchback
The 10A tail is fine, there is no panel 2, only a 7.5A panel 1 beside the 10A tail, and it is fine.
This is what I have for the headlight switch connector
Sorry I had to use a picture from another forum, best I could do in short notice.
I tested the connection for continuity.
The one thing I noticed is that the left front parking light (inside the headlight assembly) is burned out.
Thanks
Nadial is offline   Reply With Quote
Old 08-12-2013, 02:56 PM   #2
Thanks
OK. In that case, if you simply jump the white wire to one of the white/black wires (you can use a paper clip or piece of wire to do so, you should see the tail lights come on). This would do the same thing as the parking light - output on the remote starter.
If you do, then something is not configured correctly with the remote starter or the connection to that wire is not good.
Old 08-12-2013, 03:55 PM   #3
Nadial
Jumped the wires and the tail lights came on. Made sure the connection between the alarm and the white wire on the plug is fine. Reset defaults on the alarm as well, no luck.
I am out of ideas. Maybe just live without the lights flashing.
Old 08-12-2013, 04:17 PM   #4
It sounds like that output is bad on the remote starter.
Old 08-12-2013, 05:44 PM   #5
Nadial
Unfortunately I think you are correct. I've already got the alarm wired, maybe the guy I bought it from will give me just a new module, because I don't want to undo everything I have done.
Thanks again for your efforts CTScott
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
