![]() Drives: Yaris S 2007 Join Date: Feb 2013
![]() ![]() Hello.Some time ago I had problems with the code 14 in the end the problem was the wiring. A couple of weeks ago, the srs light was returning to be turned on, but only when he turned the wheel, was paid in the next engine start. Yesterday, I remain fixed, I thought it was past connections, so I went back to splice the wires. Now I have the code 14 and 51, my question is, if I change the front sensor wires with the battery connected, the code 14 again, or should automatically eliminate, or scanner is required to remove it. The 51 is the spiral cable, even should I check. I appreciate your valuable help, I'm desperate for that light. |
#2 | |
| Tags |
| airbag |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 01:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 09:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
