Old 08-19-2013, 01:14 PM   #1
edelgados27
edelgados27's Avatar
Drives: Yaris S 2007
Thanks for the reply.
Again turn off the light, but determined that only turns on when I move the steering wheel fully to the left, for example in reverse.
As one of the codes is 51, is likely to be the coiled cable, for the symptoms.
With the lights out, if I use the cable actually tells me that the error codes are 14 and 51, the 14 and this resulted for months but 51 is new.
It's interesting, because when I turn on the light, to turn off and on the engine shuts down, the initial check.
edelgados27 is offline   Reply With Quote
Old 08-19-2013, 01:22 PM   #2
Yes - 51 is the spiral cable. With it coming back when you turn the wheel fully to one side the ribbon cable inside of it has a damaged spot.
airbag
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 01:35 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 09:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 04:41 AM
