![]() ![]() ![]() Drives: Yaris SR '12 Join Date: Jan 2013
Want fog light projectors
Hey all
As the title states, I'm looking to potential upgrade my fog light fittings on a third gen Yaris to projectors. Any out there that are recommended? I'm using my fogs as DRLs at the moment and I like that clear light output you get from projectors. Thanks in advance!
![]() The forever growing to do / to buy list: FIX Projectors - FINALLY DONE! XB LED fogs - Done Lowering springs - Done MOMO Revenge Evo X - Currently selling body parts for Declare bankruptcy - Done |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
Garm use to have them listed in his store but I cant find them anymore. Shoot him an email and see if he has any left over or can order a set
Thanks for the reply. Will go ahead and send over an email. Are they a straight replacement for the yaris then? And while its mentioned, anyone got any photos of them installed?
We had projector foglights for the sedan, but I'm not sure if we did for the liftback. I'll have to look back through the orders to see.
Form>Function
Oh I didnt know they were different
Thank you! It is lift back I'm after. I've mentioned previously but it's for the 3rd gen as well.
I haven't seen any projector fogs for the 3rd gen liftback. Always looking though.
Thank you :) please let us know if you do find something!
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
after my wife takes delivery of her yaris i will be doing some measureing to see if i can get these to work, these also are ready to be wired up as high beams. they look sweet!
https://www.theretrofitsource.com/pr...ducts_id=18725 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Do a retrofit....I did. Since the Mini H1 Headlight Retro Fit went so well. Was considering the projector fogs.
Some photos taken from here:FOG COMPARISON :: Hella, Blazer, Bosch, OEM Reflector But wasn't happy with the beam pattern as fog lights... but they make a GREAT driving light with a GREAT cut off...but no foreground for fog light use...but after seeing the light pattern from the Hella Micro De Fog Light - pretty sure this is what I'll use: ![]() Comparison of the light pattern - Blazer has awesome cutoff but barely any foreground: ![]() ![]() I'll like mount them in the yellow lens housing foglights to keep the look I already have: ![]() Retro fitting - Kinda like this - using a circle cutter or dremel to round out the back housing to mount the Hellas in the OEM fog light - thus retaining mounting points and aiming capability. I will be using a H3 3000k HID 55W setup with this. ![]() (FYI...the above fog lights aren't mind or the oem 3" fog lights - this image was pulled from a Tacoma retrofit using 4" fog lights.) |
So the lights came in...
![]() But the OEM housing is a PITA to cut open...must be die-cast aluminum. ![]()
...and Finished!
Hella Micro De mounted with JBWELD to OEM cast aluminum fog light ![]() ![]() Broke the glass lens while trying to separate the glass from the housing, ended up getting some .25" glass cut to 3.5" circles then coated them with 3 coats of Dupli-color Metalcast Yellow from TCPGlobal and 2 coats of clear spray paint to get the yellow lens look I wanted. Then resealed the lens with a waterproof silicone. You can see that the paint isn't 100% clear but doesn't stop the 3000k HID bulbs much. The good thing about doing the paint this way, I can remove the yellow paint at anytime in case I want to change the color of the bulb or lens and no longer have yellow fog lights but a 5000k driving light. ![]() H3 3000k HID bulb held in by (6) washers ![]() Because of the new length and size of fog light the bumper mounts for the oem bulb had to modifed and resized as well as a hole had to be opened behind the headlight for the length and the back of the HID bulb wires. This is a picture of roughly what was done with a dremel. OEM ---------------------------------------------------------Modified ![]() Installed ![]() Just need the adjust the aiming...will have that done hopefully this wknd.
yarisgeo13
Drives: gloss black 5 door Join Date: Sep 2013
Nice addition on the lights.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 04:27 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
