One of mine used to do it and I initially thought it was coming from the driver's side spring perch, but it turned out to be the rear brake. When I cleaned and relubed the rear brakes it went away.
![]() Drives: 2004 Toyota Allex Join Date: Aug 2013
There are a few points of contact for the shoes within the drum where you apply high temperature brake grease. Over time that grease gets coated with brake dust and that is when they start making noise.
See the "brake" section of the service manual for the grease points: http://www.microimageonline.com/foru...32-YARIS-FILES
#4 | |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| metal snapping sound on front end when braking... | marcus | General Yaris / Vitz Discussion | 25 | 11-26-2010 10:29 AM |
| Metal on metal rotating wheel noise | phyrefighterjay | General Yaris / Vitz Discussion | 7 | 04-19-2010 11:31 AM |
