Old 08-29-2013, 12:59 AM   #1
coolcat21
Drives: 2004 Toyota Allex
One of mine used to do it and I initially thought it was coming from the driver's side spring perch, but it turned out to be the rear brake. When I cleaned and relubed the rear brakes it went away.
How do you relube a drum brake (shoe? ) ?
coolcat21 is offline   Reply With Quote
Old 08-29-2013, 06:14 AM   #2
There are a few points of contact for the shoes within the drum where you apply high temperature brake grease. Over time that grease gets coated with brake dust and that is when they start making noise.
See the "brake" section of the service manual for the grease points:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 08-29-2013, 07:10 PM   #3
coolcat21
Thanks for this !
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
metal snapping sound on front end when braking... marcus General Yaris / Vitz Discussion 25 11-26-2010 10:29 AM
Metal on metal rotating wheel noise phyrefighterjay General Yaris / Vitz Discussion 7 04-19-2010 11:31 AM
