Old 08-29-2013, 11:19 PM   #1
YarisAddict
Drives: 09 Yaris 3drHatch
No Tach reading
I Spliced the green wire into an orange wire that is on the far bottom left on the ecu port. I've read online that that was where I'm supposed to do it since I have tire pressure monitor. The orange wire is in replace of the greenish blue wire your talking about in cars with tire pressure monitor. It has been driving me crazy that it wont read rpms. Lights work and it has power, also I put my ground exactly where you have yours. Any Ideas?
Thx
09 Yaris3drhatch
YarisAddict is offline   Reply With Quote
Old 08-29-2013, 11:22 PM   #2
Thx
09 Yaris3drhatch
The orange wire is the correct one for your car. Double check your splice, particularly if you used a tap splice, as that wire is only about 24 AWG, so the tap splice needs to be a tiny one to make a proper connection.
Old 08-30-2013, 12:45 AM   #3
YarisAddict
I used the one that came with the kit. Is there any other way to splice the wires together? I'm just afraid now that the orange wire is basically in half once I remove that little plastic connector. Sorry I'm a noob when it comes to the wiring side of things.
Old 08-30-2013, 06:53 AM   #4
The best method is to strip insulation off both wires and solder them together and then tape or heat shrink. But, crimp on splices are fine as long as they are the correct size for the wires. If you remove yours and find it did cut the wire, it is actually not a big deal, since the tach signal to the OBD connector is really not used by anything.
Liftback Spoiler Installation Toddhata Cosmetic Modifications (Exterior/Interior) 25 08-09-2009 01:26 AM
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 08:23 AM
