Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
random cel flashing
I should begin with the first incident...
a few months ago I was in the mountains for my honeymoon while acellerating full throttle up a steep on ramp I had to drop in power followed immediately by flashing check engine light. then I had a steady light on which turned out to be a misfire code so I replaced the plugs with fresh NGK iridiums later that week the car had a little under 60,000 miles. All has been well. today i was in heavy excess of traffic and just when I thought I should probably still turbo this car traffic suddenly cleared and I did a third gear pull. As I approached redline...the car studdered lightly and then started flashing the CEL at me so I'll let off and coasted for a moment...then i went full throttle again and then it did it again and I did it two more times what's the same results. I tried again a few more times later down the road but I was only in 5th gear and all was well mind you the car has about 63,000 miles is this a coil pack issue?? I have no constant CEL so have nothing to scan.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
| CEL afer oil pressure light | andysong | DIY / Maintenance / Service | 8 | 03-06-2020 02:57 PM |
| Help! CEL P0420 | kwkshft | DIY / Maintenance / Service | 10 | 03-15-2014 09:10 PM |
| 2001 Yaris flashing hazards when ignition off!!!?! | 4odh4n | DIY / Maintenance / Service | 7 | 01-20-2012 05:51 AM |
| HELP! Random Engine Cut-Off!!! | YarisPR | General Yaris / Vitz Discussion | 12 | 04-07-2011 12:41 AM |
| Car shaking cel flashing? | jamal1984 | General Yaris / Vitz Discussion | 7 | 10-16-2010 06:31 PM |
