![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
Took it out and they tested it in the machine.
It's either bad, or the ground or power connection from it is heavily corroded. The big wire that is bolted under the grey plastic cover is the positive wire, which goes right to the back of the positive battery terminal. The ground is its case contacting the block. So, the ground straps from the block to the negative terminal are what you want to check on that side.
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
