![]() Drives: 2007 Toyota Yaris Join Date: Jan 2010
So what would have caused this after a cam sensor replacement?
If the error clears and stays away then it is likely that they turned the ignition on with something disconnected. If it doesn't clear, then I would suspect a damaged wire going to the ABS ECU.
| Error code of P0010 on diagnostic test | Stacy Travis | DIY / Maintenance / Service | 2 | 08-31-2013 08:44 AM |
| P0010 OBDII scan code | yaitsme | DIY / Maintenance / Service | 2 | 04-08-2013 11:24 PM |
| Code p0010 | Ckern67 | DIY / Maintenance / Service | 1 | 11-26-2011 10:57 PM |
