Old 09-08-2013, 04:33 AM   #1
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Come back in another 60,000 Miles. I am not joking .. these cars are so good that is really what I am recommending. Other than the usual things like oil changes, tires .. and maybe a battery you should be good to go for another 60,000.
My car at just over 100,000 miles ... and the only maintenance things I have had done is ... tires, a battery (after 6.5 years) and a water pump (warranty issue). ABS brake issue (well documented here on this forum) .. but that was covered under warranty.
edmscan is offline   Reply With Quote
Old 09-08-2013, 03:18 PM   #2
nookandcrannycar
^^^^^ This.
Other than maintenance things (oil/oil filter/air filter/tires/battery/spark plugs,etc....generally done very sparingly) at 256,000 plus miles I've only replaced the front wheel bearings at 110,000 plus and the alternator at 159,000 plus. The alternator on my model year (2007) has a known defect (faulty voltage regulator, I believe (and IIRC the voltage regulator on a 2007 Yaris is inside the alternator) and I believe this was corrected for the 2008 (and obviously after that) model year.
Any Exhaust Tip Recommendations? Z00KA Cosmetic Modifications (Exterior/Interior) 10 08-11-2011 12:59 PM
Recommendations on Mass Air Flow Sensor (MAF) dyslexicanaboko Performance Modifications 11 02-08-2011 10:24 PM
Any recommendations on interior cleaning products? psx180sx Wash, Wax, Detailing, Exterior Repairs 4 03-22-2009 12:30 AM
Scooter recommendations turboecho2005 Off-topic / Other Cars / Everything else Discussions 3 03-13-2009 03:41 AM
