Old 09-09-2013, 04:42 PM   #1
Originally Posted by shaunalvarez View Post
and I tried the normal way of pushing the sides in on the glovebox to drop it down and the plastic is too stiff or too new to push in
It is stiff. I discovered with mine (2nd gen) that I had to push in the sides to the point where I thought for sure something was going to snap. It didn't though, and popped free.
Old 09-09-2013, 06:23 PM   #2
shaunalvarez
Drives: Yaris 2013
I got it off took me like 10 attempts I was already storming up a plan to get it fixed under guarantee if it broke apart found it easy by doing the left side first and I wedged a screwdriver to pop each side out.
anyway most of it is done I passed the speaker wires and positive and negative cables and taped up most the cables to make it look neat.
whats left is to connect is the cables to the battery and figure out where im going to bolt the unit to inside, can I jump the negative wire to the negative terminal of the battery so I don't have to look for a grounding srew or bolt?
shaunalvarez is offline   Reply With Quote
Aux cable for 'old' Yaris Yarisfan_BE In Car Entertainment + Electronics (audio / video / alarm) 1 04-21-2009 09:51 AM
