Old 09-11-2013, 11:18 AM   #1
gopacks12
gopacks12's Avatar
Drives: 2007 Toyota Yaris Sedan 5MT
Was your car in an accident?
35 is the seat position sensor, which is a device mounted to the bottom of the driver's side seat rail to detect if the driver is close to or far from the steering wheel.
37 is the driver's side buckle switch, which is a hall effect sensor mounted within the seat belt latch to detect if the buckle is clicked or not.
Those two giving errors would make me first check to see if the connectors are plugged in under the driver's seat.
51 is a short in the steering wheel airbag. That one is most likely due to a bad spiral cable (AKA clockspring), which is the device under the steering wheel that allows the steering wheel to rotate while maintaining the connection to the airbag and horn.
Yeah my front bumber was shattered back in december (air bags didnt go off) and about a month ago i was rear ended (airbags didnt deploy either). Cracked my bumber.
When the SRS first started coming on I was looking threw the threads on here and one did say check the connections under the driver seat so i gave it a shot. I unplugged the connectors while the car was still running (i know stupid right) then re plugged it in again. Maybe thats why its showing me 35, 37.
I probably have to do that jumper trick to get rid of codes 35, 37.
Im pretty sure the SRS light is coming on mainly because of the clockspring since it only happens after a few turns of the steering wheel.
gopacks12 is offline   Reply With Quote
Old 09-11-2013, 11:34 AM   #2
Ah, that makes sense. And, I do believe that the 35 and 37 are codes which will not automatically clear, so you will have to do the jumper trick to clear them.
Aftermarket clocksprings have popped up on ebay for around $50. I am not sure of the quality, but they are a whole lot cheaper than OEM ones.
Old 09-11-2013, 01:06 PM   #3
gopacks12
gopacks12's Avatar
Yea I found one for $40
Is there a DIY clockspring replacment tutorial thread on here somewhere?
Old 09-11-2013, 01:42 PM   #4
Here's a video I put together on doing so:
http://www.youtube.com/watch?v=LgWSzVeILhc
Old 09-16-2013, 12:59 PM   #5
gopacks12
gopacks12's Avatar
thanks!
ill check it out
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
