Old 09-12-2013, 05:23 PM   #1
d3310n
Drives: black titty
17x7 +42mm should be just fine.
To get the real performance value from those springs, you're going to want Tokico shocks to go with them.
Haha I know. What do the performance shocks do better than the stocks? Should I get those next or a swaybar
Originally Posted by Golddeenoh View Post
lol, sales pitch much.
Lol. But understandable, he will have a repeat customer here
d3310n is offline   Reply With Quote
Old 09-12-2013, 08:23 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by d3310n View Post
Haha I know. What do the performance shocks do better than the stocks? Should I get those next or a swaybar?
They decrease the rebound or "springiness" of your springs and keep the wheels in contact with the pavement instead of bouncing the car around.
The swaybar is a smaller investment with more bang for the buck, and only takes a few minutes to install (if you have a breaker bar and a torque wrench). When you're ready for shocks, save up some extra cash and get the Tokico "reds". They have adjustable dampening so you can turn up/down the firmness of your ride depending on what you're doing. I went with blues because they were less expensive, but there isn't an autoX event that goes by where I second guess that choice.
If you want/need a winter setup, you can also get the OEM parts to complete the front suspension assembly and make the whole spring/shock modular. Just be sure to get the right tools for removing your OEM springs--the tension on those things can REALLY injure you when they come loose.
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
