Old 09-18-2013, 04:22 PM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I disagree with WeeYari, I have run 45/50 on 15s 40/45/55 on 16s without issue. The shorter the sidewall the lower you will be to the ground and give the harsher the ride. Thicker side walls are usually more cushy.
Its going to come down to your wheel preference. Find the wheel you want and then find a tire to match.
Think of what you want out of your new tire/wheel setup like weight, performance, looks, stance, handling, etc thats a good way to start
Old 03-30-2014, 07:58 PM   #2
Rigaud
Drives: 2009 Yaris
Precisely. If you go with lower profile sidewalls then invest in better shocks/struts. Your ride will be harsh. Theirs always a domino effect when you start changing your cars set up from stock specs. Been doing this for almost 33 years now, I see all kinds of messed up upgrades or set ups still.
Rigaud is offline   Reply With Quote
Old 12-07-2014, 08:17 PM   #3
Ben_
Drives: 2010 Yaris Hatch
how about 225/45/15x7 et40 with coilovers? will this need spacers?
Ben_ is offline   Reply With Quote
Old 12-17-2014, 05:58 PM   #4
225s! You trying to float the thing on water?
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
