Old 09-23-2013, 04:14 PM   #1
adrew
Drives: '12 L 3-door 5-speed
They came on my '12 in 175/65/15 (H-rated, made in Japan). I've had a lot worse OEM tires, but I wouldn't buy these again.
They were great for the first 12k miles or so, then started to get slippery on wet roads. They're quiet and ride well but the sidewall is soft and steering response is slow. They also howl and squeal with any kind of slightly enthusiastic cornering. I will say that the '12 consistently gets 2-3 more MPG than our '11 that has Bridgestone RE92s on it, but that could be a result of refinements between the two different generations of cars.
I'm going to try and tolerate them for another year or so (they don't seem to be wearing at all!) and then switch to the Michelin Pilot Sport A/S 3 (comes in 175/65/15, presumably since that is the size the base Mini Cooper wears).
adrew is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
