#1 | |
Got my Spoon collars in the mail the other day and installed them today. Not too impressed with them for a few reasons. The collars themselves seem fine however the instructions are all in Japanese. They offer a page with poorly written English on them but it just says some common sense safety info, not any useful images or instructions like the japanese ones.
The diagrams are all from what I think is a Prius subframe so although similar, it has a handful of extra bolts. My box never came with any rears which I was expecting as it only stated front and I already have rear TRD collars. The box comes with 2 collars total. 1 you use on each side for the front most mounting point of the subframe. And 2 you use on each side of the middle mounting point on the subframe that goes through the control arm bushing. They send an extra 2 as it appears based on the diagram that depending on your chassis you use one or the other. So for a stupid high price you essentially get collars for only 2 out of the 3 mounting point on our Yaris subframe. The rear mounting point would be the simplest of all the point to manufacture one collar for. Since I have Whiteline collars that came with my bushings, I essentially can only use the front most collar. I ended up using one of the control arms bushings for the rear most mounting point on the subframe. It isn't snug enough so won't do much but it is better than the original large hole on the subframe and helps fill the gap. All in all, over priced, poorly explained product that doesn't even cover all the points you need. Not sure what other people on this thread were posting about but the product that I purchased from RHD Japan was the same thing but it seems no one else had this issue. Pics from others of the subframe would be appreciated to figure out what exactly they purchased and installed
DKDC
Drives: Yarlet Join Date: Aug 2006
Too bad you're not happy with them. Most gray market items will come with little to no english instructions. Also, the front and rear collars are separate. I only have the front. In the rear I have the trd hardened shock bushings and no collars on the lower trailing arm/axel.
(dick measuring info goes here) |
![]() Drives: Toyota Echo Join Date: Oct 2016
For anyone else wanting to install/needs reference material in installing these.
https://www.rigidcollar.jp/blog/2014...4%9C%E8%A8%BC/ |
#5 | |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
Just out of curiosity, doesn't this eliminate the ability to adjust caster?
#7 | |
Caster isn't really adjustable anyways as it's dictated by the bushing on the rear of the front lower control arm. You adjust caster by installing aftermarket offset caster bushings instead. Sent from my SM-G950F using Tapatalk |
With the control arms being bolted to the subframe and the shocks to the chassis, if you slide the subframe forward you can gain a little positive castor as this move the bottom of the shock forward. Do the opposite and you have some negative castor. Might be only a few millimeters of play here but those few millimeters make a big difference relative to the system. Granted, I don't see your average everyday person doing this but it's there.
#9 | |
Spoon Rigid Collars NCP91
Merry Xmas guys,
I have just received my Spoon Fron Subframe Collars and planned on doing the installation in the next days. The kits come with instruction but it is in Jampanese and I am not so good at that. I did some rearchs on the web but could not find anything details the process. So I was wondering if anyone here had done one before and how difficult is the whole process? Do I need to remove anythinge.g. overpipe and etc else rather than the Subframe bolts? How many trolls jacks do I need to hold the front Subframe? Any info will be really appreciated... Thanks |
Take a look at this. https://www.rigidcollar.jp/blog/2014...4%9C%E8%A8%BC/
You shouldn't really have to unbolt anything unless it you have a brace. Best way to install it is to jack the car up on some stands and then use the jack to brace & lower the subframe abit as you back out the 4 subframe bolts far enough to slip in the collars when you remove 1 of the 4 bolts then put the bolt back in after you've installed it. You may need a pry bar to pry the subframe for that extra clearance as it still has the rear engine mount which could cause the subframe not to lower far enough for you to slip the collar in. |
| FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) | Treyz | Items for Sale by private party | 22 | 04-08-2014 06:17 PM |
| RZCrew Garage Rigid Collars | Chuckie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 02-13-2014 12:34 AM |
| SilkRoad NCP91 Coilovers In-Stock! | Penguin Garage | Penguin Garage | 28 | 07-12-2009 05:48 PM |
