Old 10-01-2013, 04:51 PM   #1
rcvmini
Drives: 2009 Yaris HB
larger diameter from OEM can effect MPG for the worse and speedo readings. Either by means of larger rim or larger tires on same size rim. Larger usually means heavier which will decrease performance on these low hp cars
Smaller diamber from OEM can also effect MPG for the better and speedo reading. Using lower profile tires on same rim or smaller rims in general. Usually weigh less and the smaller diameter changes the gear ratio which helps in acceleration.
I see no gain or loss with those Acura rims on craigslist. Only issue I see is the Acura logo on the caps which will look silly on a yaris.
ilikerice - hey i like the colour scheme of your yaris with the red on the rims.
As long as the rims fit, I can deal with the acura symbols in the center (paint over them etc) as I may plasti dip them white or black and then ad a trim colour with rim tape.
Thanks for the info on bigger rims i was looking for 16's but these seem to be a good deal and i don't mind 15s
rcvmini is offline   Reply With Quote
Embarassing Newbie question Chicken Little Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-12-2013 11:17 PM
Newbie wheel question... :) sorry if its a repeat. Gearheadb6 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 05-29-2012 06:53 PM
Newbie Question on Acceleration soup1207 General Yaris / Vitz Discussion 8 07-26-2010 12:00 PM
rim question SurfBabe900 New YARIS Purchase Forum 2 05-23-2007 03:55 PM
