![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
I have the exact same Rzcrew collars as you, my friend. It is all written very clearly on the given instruction. Guess your mechanic is lazy to read the given instruction. I even double confirm with Rzcrew guys, yours is installed wrongly. I believe you can feel MUCH MORE benefit if you install it correctly. ;)
At least your rear is correct. Go back to your mechanic and get him to complete the correct job for the front 6 collars.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
#2 | |
![]() ![]() Drives: 2011 Yaris Hatchback Join Date: Sep 2013
#3 | |
Yes you're correct for the very front as well. Which is the hardest part to get it install as it is mount right up on our 2 main frame chassis. And the arms is blocking up the way to get it install. Do it the right way, buddy!! You'll get it MUCH MORE advantage than just mounting it on the bolts. The only thing you'll need to worry about it now is, the collars might be "compressed/deform" due to the tightening on the collars. As you can see, the collars have a very tiny flange on both side.
^^ ok .. I just contacted our supplier here. He said the two in the very front were installed correctly. So now I just have to correct the ones where the strut bar goes. Hope they arent deformed yet..had them on for three weeks.. What you think?
| DIY Stealth Garage Door Opener Button | PatrickJohnson | DIY / Maintenance / Service | 38 | 10-08-2010 02:42 PM |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Penguin Garage Rear Hub Spacer Raffle!! | Penguin Garage | General Yaris / Vitz Discussion | 27 | 06-30-2009 01:05 AM |
| ****Kami Speeds 09 Garage Sale/Meet****, up to 60% off everything in stock!!! | SAKU | Off-topic / Other Cars / Everything else Discussions | 9 | 06-10-2009 11:50 AM |
| Need help finding a garage remote | Lafiro | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 11-26-2006 10:14 PM |
