![]() Drives: 2011 Yaris 3dr Join Date: May 2013
A larger diameter means less revolutions per a given distance (effectively a higher gear ratio) but you run into fitment issues with larger diameters or they rub when turning or going over bumps. It's a good idea to stick close to the stock tire diameter. Also with offset, the lower the offset, the farther the tire "sticks out", too low and you will rub your fenders on bumps. Too high and the wheel might hit the suspension.
#2 | |
![]() Drives: 2000 Toyota Vitz (scp10) Join Date: Oct 2013
Thank you for the very informative advice! I have 2 preferences atm 195/55r15 6.5j +28 185/55r15 5.5j +45 What do you think is good for my car? And do i also need to adjust the suspension? |
| Changing to cold air intake and insurance problem | ExtremeCold | Fuel Economy Forum | 7 | 04-24-2011 08:20 PM |
| Changing to cold air intake and issurance problem | ExtremeCold | Performance Modifications | 19 | 04-09-2011 05:15 PM |
| WTT: Yaris TS 15" for RS 15" | IllusionX | Canada | 9 | 04-22-2010 11:57 AM |
| change rims from 15" to 17" on yaris HB | yarismo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 02-16-2010 01:01 AM |
| Changing the oil | lita_g | DIY / Maintenance / Service | 18 | 10-28-2008 02:59 PM |
