Old 10-11-2013, 09:36 AM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
For the dome light, the Body ECU drives it and although I can't identify the 3 terminal driving device, I would say that by its size that it should be able to handle 1A.
Can you take a photo of its marking?
I am a bit into this switching stuff ;)
There seems to be a relay inside the Body ECU, the pins on the dome light connector it is connected to are not used, the resistance is 180 Ohms if I remember correctly and letting current flow through it results in a "click".
I could not figure out what it should switch
dj92 is offline   Reply With Quote
Old 10-11-2013, 12:36 PM   #2
When I have an opportunity I will pull one apart and snap a pic.
Old 10-12-2013, 05:35 PM   #3
dj92
Embracing Curves
dj92's Avatar
(I will begin to work off my questions I have gathered in the last months if you are comfortable with this)
I have discovered 3 female connectors I struggle to identify (maybe I can use them for own projects).
These are one behind the shifting stick and two between stereo and AC.
I checked the manual's EWDs, but I could not track them really down.
The connector behind the shifting stick has one row of wires with a 0,1" spacing (2,54mm).
The colours and what I have found out up to now:
White - GND
Grey - 12V if headlight is on
Cyan/ mint green
Yellow - 12V IGN
Magenta - 12V IGN
Blue
White with black stripes
the 8th slot is not used.
The first connector between stereo and AC has two rows and looks like a shielded audio cable is connected to it.
It seems to belong to the stereo, but what confuses me is the fact that there is exactly one cable that looks like this on the radio connector and what looks like its other end leads to the aux connector.
Maybe it's a Y-cable?
And what confuses me most:
The 3rd connector which has about 5 pins and 3 wires.
The wire in the middle has an impedance of about 5 to 10kOhms.
The voltages are:
ACC off: 0V
ACC on: 3..5V
IGN on: 12V
IGN->ACC: slowly dropping to 3...5V (maybe a capacitor discharging?)
The other two wires are connected to GND.
I have pulled fuses and found out that it gets current via the ACC-fuse when in ACC, when IGN is on, its the AM2 fuse.
Additionally: The US manual does not mention the seat heating wiring (fuses: SHTR 1 and SHTR 2 iirc)
Does someone have access to information about this?
Thanks in advance!
