Old 10-11-2013, 10:16 AM   #1
Most auto parts stores will read codes for no charge.
That's an American luxury. Very hard pressed in Canada to find someone who will not soak you for an easy $100 to plug in a code reader.
Old 10-11-2013, 02:47 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
just to let u know our pc with build in code reader and everything else possible that one can do to a toyota is $ 6k to buy we got 3 of them...anyone is welcome to buy a cheap just code reader at CT...that is once choice but as for free i dont agree...the place pays good money for the equipment i pay crazy money for my tools went to school also...so what makes u think it should be free ..warrant will cover lots ...but dont expect anyone to do anything free.
just my 2 cents on this ....at least we will get it right the first time not like ur average shop.
Old 10-11-2013, 03:17 PM   #3
barryware
In the US.. ALL the parts stores will read your codes for free.. They do this so you will buy the repair parts needed to correct the problem. Most other shops (Sears, Midas Muffler, etc.) will also read the codes for free in hopes you will let them fix the problem.
Most can only read the ECM.. Any of the other computers on the car (power steering, body, A/C, etc.) takes the techstream or some other sophisticated, expensive head tool which some shops have, and some do not.
My 2 cents..
barryware is offline   Reply With Quote
Old 10-11-2013, 04:05 PM   #4
^ This.
I can't tell you how many times a Canadian on this site has posted concerning check engine light, and they will almost always get a 'most auto parts (ie. AutoZone) will scan for free' response.
We don't have AutoZone here with the closest comparable being PartsSource and NAPA. Both these operations do not extend this service under the hope that you will buy your parts from them. The closest we do get is the periodic special run by some shops who will wave the diagnostic fee if you have them perform the necessary repairs. Otherwise, it is pay for the read + parts + labour.
I'm not dumping here, just pointing out that the free diagnostic from your local parts store is not an applicable response for us.
Old 10-12-2013, 09:49 AM   #5
barryware
^ This.
Fair enough.. Another option would be to purchase a code reader. I see some pretty cheap ones but if the problem is anywhere other than the ecu (trans, body, power steering, etc..) it won't tell you much.
You could also purchase a device that does more than read codes. I bought a scanguage II and it is always connected to my yaris. My car does not have a tach so I bought it just for that. It gives all kinds of info and reads / clears codes (but not anything other than the ecu).
Since, I bought an additional cable so I can use it to read codes on other cars without having to dig out the cable that is installed in my yaris. It seems I read the codes on one car (for fun mostly), and I have now turned into the neighborhood / family code reader.
Then.. you have to interpret the code to pinpoint the problem. Sometimes, it is best to just bring it in.
The OP states he has low mileage and the car is a 2010. It was also indicated that the car is under warranty. They charge for reading codes in Canada when the car is under warranty?
My yaris came with a 36k mile / 3 year warranty which is pretty poor. Not unlike the Honda's though.
My wifes GM car came with a 4 year / 50k mile warranty (bumper to bumper) and 100k on the engine and drive train.
What about battery testing... Do the stores in Canada charge for a battery test?
Old 10-12-2013, 11:35 AM   #6
I personally have one.
Likewise. Since getting mine, I have done approx. $700 worth or reads.
Usually, yes.
Some do, some don't
Old 10-12-2013, 12:46 PM   #7
barryware
Usually, yes.
Boy oh boy.. I would have a problem with that.. My car is under warranty.. CEL came on.. Fix it!
Old 10-12-2013, 12:23 PM   #8
Neurotic Hapi Snak
Drives: 2011 Yaris 3dr
Toyota also has an extended powertrain warranty, 5 years/ 60k miles.
Neurotic Hapi Snak is offline   Reply With Quote
Old 10-14-2013, 01:57 PM   #9
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
Scan should be free as a loyal customer who will get the repairs or parts at that shop.
When you get a brake job, do they charge you "diagnostic fees" of $30 to tell you that you need new brakes? No.
We pay mechanics to find the problem and fix it. Just because they want to use a computer at MY expense, doesn't sit right with me.
caper26 is offline   Reply With Quote
Old 10-15-2013, 02:34 PM   #10
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Often poorly done work (e.g. not checking a battery that was in fact dead and blaming it on the ECM) let me come to the decision to fix my cars on my own, including maintenance.
In the end, it saves me a lot.
I had changed the air filters in less than half a minute, changing oil and its filter were done in less than an hour.
~20€ or so for the 3 filters, 50 for a canister of oil that's still got about 2l in it, that's totally okay for me to spend that every second or third year.
Paying the workshop 100€ in addition (some rumors said even 200€) isn't at all.
I lose the rust warranty, but if it rusts too bad in about 10 years or so, the saved money will be by far enough to fix it
dj92 is offline   Reply With Quote
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
yaris engine check light keeps coming on mattuk10 DIY / Maintenance / Service 6 07-24-2010 11:44 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
