Old 04-05-2007, 10:04 PM   #1
Edd
Drives: None
What the **** is up with people saying it is dangerous to go higher with octane? The manual gives you the LOWEST octane rating the car will run on. The higher the number, the better. There is no damage from going to a higher octane level - you are just putting in purer fuel.
Edd is offline
Old 04-05-2007, 10:07 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
wrong- higher octane has more additives
Black Yaris is offline
Old 04-05-2007, 11:26 PM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
Octane is not a measurement of caloric content or burn-ability (cetane). It is a measurement of how high a temperature is needed in order to ignite the fuel. This is why premium fuel is usually only required on high performance engines (because they run at higher compression levels which generates more heat).
Higher octane fuel is actually less pure because of the extra additives which are used to make the fuel ignite at a higher temperature. These additives are also why it costs more.
Running fuel of an octane higher than what your engine is designed for can help with knock (detonation) but that is generally where the benefits stop. The detriments are:
- Fouled spark plugs due to the deposits left via incomplete burning.
- Greatly increased emissions due to incomplete burning.
- Fouled O2 sensors due to these emissions.
- Fouled catalytic converter due to these emissions.
Stick to what your engine is rated for. The 1NZ-FE engine in the Yaris is designed for 87 octane gasoline.
- Brian
Share the Road
BailOut is offline
Old 04-06-2007, 12:10 PM   #4
Pavel Olavich
Drives: 2007 Yaris LB
Finally Someone Else Is Rational Here....
AMEN Broda!!!! You wrote it right and it is right!!!!! Why some here hold on to superstitions, urban myths, or what use to work with 1960ish cars is beyond me....
Pavel Olavich is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
