Old 10-12-2013, 09:49 AM   #1
barryware
^ This.
I can't tell you how many times a Canadian on this site has posted concerning check engine light, and they will almost always get a 'most auto parts (ie. AutoZone) will scan for free' response.
We don't have AutoZone here with the closest comparable being PartsSource and NAPA. Both these operations do not extend this service under the hope that you will buy your parts from them. The closest we do get is the periodic special run by some shops who will wave the diagnostic fee if you have them perform the necessary repairs. Otherwise, it is pay for the read + parts + labour.
I'm not dumping here, just pointing out that the free diagnostic from your local parts store is not an applicable response for us.
Fair enough.. Another option would be to purchase a code reader. I see some pretty cheap ones but if the problem is anywhere other than the ecu (trans, body, power steering, etc..) it won't tell you much.
You could also purchase a device that does more than read codes. I bought a scanguage II and it is always connected to my yaris. My car does not have a tach so I bought it just for that. It gives all kinds of info and reads / clears codes (but not anything other than the ecu).
Since, I bought an additional cable so I can use it to read codes on other cars without having to dig out the cable that is installed in my yaris. It seems I read the codes on one car (for fun mostly), and I have now turned into the neighborhood / family code reader.
Then.. you have to interpret the code to pinpoint the problem. Sometimes, it is best to just bring it in.
The OP states he has low mileage and the car is a 2010. It was also indicated that the car is under warranty. They charge for reading codes in Canada when the car is under warranty?
My yaris came with a 36k mile / 3 year warranty which is pretty poor. Not unlike the Honda's though.
My wifes GM car came with a 4 year / 50k mile warranty (bumper to bumper) and 100k on the engine and drive train.
What about battery testing... Do the stores in Canada charge for a battery test?
barryware is offline   Reply With Quote
Old 10-12-2013, 11:35 AM   #2
I personally have one.
Likewise. Since getting mine, I have done approx. $700 worth or reads.
Usually, yes.
Some do, some don't
Old 10-12-2013, 12:46 PM   #3
barryware
Usually, yes.
Boy oh boy.. I would have a problem with that.. My car is under warranty.. CEL came on.. Fix it!
Old 10-14-2013, 02:00 PM   #4
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
Yes, that is my beef.
caper26 is offline   Reply With Quote
Old 10-12-2013, 12:23 PM   #5
Neurotic Hapi Snak
Drives: 2011 Yaris 3dr
Toyota also has an extended powertrain warranty, 5 years/ 60k miles.
Neurotic Hapi Snak is offline   Reply With Quote
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
yaris engine check light keeps coming on mattuk10 DIY / Maintenance / Service 6 07-24-2010 11:44 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
