Old 10-13-2013, 04:42 AM   #1
ryufrank
Drives: 07 Yaris
Oh, ok.
Thank you for your quick response though.
Well, what I am looking for according to the service manual, appears to be the T-PL relay.
I will keep on looking
ryufrank is offline   Reply With Quote
Old 10-13-2013, 05:59 AM   #2
Originally Posted by ryufrank View Post
Oh, ok.
OK - The T-LP relay is located within the body ECU, so theoretically the only way to replace it is to replace the entire body ECU assembly, which is that whole under-dash fuse panel piece.
Old 10-13-2013, 10:03 AM   #3
ryufrank
Drives: 07 Yaris
Ouch! This sucks.
The good thing is that looked further into the technical manual, and T-LP doesn't fit 100% the symptoms of my problem.
Could you please have a look into my problem?
Hopefully it might be something simple for someone with your experience.
Suddenly the first stage on the lights stick (parking lights: rear parking lights, license plate numbers, front 5W parking lights, fog lights) won't work.
Also when I turn the lights stick to the first position, not even the dashboard's lights dim down as it always did.
I believe this narrows down my problem to either issue with the stick itself, relay/fuse, or the wiring between the 2.
Thank you
Old 10-13-2013, 01:37 PM   #4
Ouch! This sucks.
Thank you
You can do an easy test to see if it is the relay or the headlight switch. The picture below is of a US Yaris headlight switch connector, but your looks the same, with possibly some wires in different positions.
To test the relay with bypassing the switch, using a paper clip or piece of wire, jump the position 10 and position 13 wires. In the picture below that would be the bottom left wire and the wire 3 positions to the right of it.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
