#1 | ||
![]() Drives: 07 Yaris Join Date: Oct 2013
The good thing is that looked further into the technical manual, and T-LP doesn't fit 100% the symptoms of my problem. Could you please have a look into my problem? Hopefully it might be something simple for someone with your experience. Quote:
Thank you |
#2 | |
You can do an easy test to see if it is the relay or the headlight switch. The picture below is of a US Yaris headlight switch connector, but your looks the same, with possibly some wires in different positions. To test the relay with bypassing the switch, using a paper clip or piece of wire, jump the position 10 and position 13 wires. In the picture below that would be the bottom left wire and the wire 3 positions to the right of it. Conn d4.jpg
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 04:11 PM |
