Old 10-13-2013, 01:37 PM   #1
Originally Posted by ryufrank View Post
Ouch! This sucks.
The good thing is that looked further into the technical manual, and T-LP doesn't fit 100% the symptoms of my problem.
Could you please have a look into my problem?
Hopefully it might be something simple for someone with your experience.
Thank you
You can do an easy test to see if it is the relay or the headlight switch. The picture below is of a US Yaris headlight switch connector, but your looks the same, with possibly some wires in different positions.
To test the relay with bypassing the switch, using a paper clip or piece of wire, jump the position 10 and position 13 wires. In the picture below that would be the bottom left wire and the wire 3 positions to the right of it.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
