Old 10-14-2013, 05:33 PM   #13
GG007
Drives: 2007 yaris hatchback
Once again, a huge THANK YOU CTScott!
With your here we successfully replaced the antenna today. I removed both rear pillar covers to allow to drop the headliner a bit more. It was tricky not to crease the headliner but possible. Screwing the nut on the new antenna was the most difficult part.
TIP: to remove the xmas tree like clip, I used a fork, turned upside down. Insert it so the middle of the clip (stub) slides between the fork tines. Then use something hard (in my case, a pen) to put under the end of the times to protect the fabric (headliner)... then simply pull the handle of the fork down... clip will come out unscathed. :)
CTScott, you were a great help!
Cheers
GG007 is offline   Reply With Quote
antenna, hatchback, headliner
Broken Antenna 2008 Hatchback Hank Corbett DIY / Maintenance / Service 9 10-15-2015 02:53 PM
Replacing Roof Top Radio Aerial (Antenna) KEVBD In Car Entertainment + Electronics (audio / video / alarm) 0 01-29-2012 02:17 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
Broken Antenna chip General Yaris / Vitz Discussion 6 06-13-2009 06:15 PM
car antenna question mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 6 12-12-2008 01:41 AM
