What are the best ways to test if a replacement clockspring is functional?
#2 | |
To test the clocksping with a multimeter, you want to test for continuity from the D18 steering column connector to the two airbag connectors. You also want to check for shorts between the pins. In the picture below, you can see the four pins on the left side connector, which are the airbag squib connections. In this view they go from 4 to 1 from left to right. At the bottom of the connector you can see two additional pins with two spring metal clips above them. They are safety pins, which short pins 1 to 2 together to disable the primary airbag squib when the connector is removed. To test the spiral cable with the connector disconnected you need to slide a little piece of plastic between the spring clips and the pins to open them up. Once you have done so you can test for continuity. Pin 4 (left most in picture) connects to the yellow/red wire on the black connector Pin 3 connects to the yellow/green wire on the black connector Pin 2 connects to the yellow wire on the orange connector Pin 1 (right most in picture) connects to the yellow/black wire on the orange connector With the multimeter you should see continuity (0 ohms in resistance setting between the two ends of each of the 4 connections). Airbag connector.jpg
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 12:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
